Swap brembo caliper for Acura?
05-6MT-TL
i gave my son my 2005 Acura TL 6 speed. The calipers are nearing the end of life after 240,000 miles and to save him some money was wondering if we can swap the calipers with standard (non-brembo) calipers? I'm prettty sure the rotor diameter is smaller for standard caliper too?Is it just a matter of removing old and bolting on new non-brembo? Will the bolt holes on the knuckle line up or does this need to be replaced too?
05-6MT-TL
Rebuilding them is the way to go, time consuming and at times a pain, so take a look at RockAuto as they have the 4 piston fronts for $48 ea + shipping. There is a core deposit, but that will be returned when the old units are sent back.
Use code 6180929615713113, expires 7/2, 5% discount. Place the code in "How did you hear about us".
The following 4 users liked this post by Turbonut:
You'd basically doing the opposite of a Brembo swap which wouldn't make sense because you'd be downgrading your car's brake performance
You can follow this DIY backwards to achieve what you want:
https://acurazine.com/forums/3g-tl-p...s-list-716463/
Latent car nut
justnspace (05-11-2017)
Stay Out Of the Left Lane
Received 1,245 Likes
OP, go the Rock Auto route. Save money for when he burns the clutch out
Latent car nut
Don't want to look this up at work, I can do it tonight at home, but do you have the part number or link handy? I believe the passenger side Brembo caliper on my 08 TL-S is hanging up. Definitely need to look into rebuilding as well. Anyone have recommendations for a good rebuild kit?
Right front: More Information for A-1 CARDONE 192892
The DVD-A Script Guy
Was also looking at the A-1 Cardone stuff this morning. Anyone have any experience with them? Price seems a bit too good to be true.
Doing a full front/rear rotor/pad job on my MT this weekend so surveying options if I need them. Recently had pads out and verified all pistons still move really well (flush brake fluid frequently) but still dreading a caliper bolt/thread disaster. (Have the time-sert kit on hand, new caliper bolts, and a bench top drill press, but still...all the horor stories)
This is why I fear my next brake job. I am hoping I can just get away with a pad replacement only and nothing else...otherwise I know for sure I will have issues with the threads....and I don't have a drill press.
Actually the same A1 Cardone units can be had from Advance Auto $73 each side.
Heck, the damn time-sert kit costs more than a pair of remanned calipers. Sounds like a no brainer to me
Edit: although a time sert permanently solves the dissimilar metal corrosion issue and a remanned caliper won't....
Good question. I'd hope that they time sert them If I knew the remmaned calipers had time serts, I'd be all over them
