Subwoofer causing headlight to go out?
Old Apr 14, 2009 | 08:32 AM
Dgreen06TL's Avatar
8th Gear
Whats up. I have an 06 TL and got a system put in. I had the factory amp bypassed to an aftermarket 4-channel to power the interior speakers. I also hooked up a 12" L5 solar baric. For some reason now when im driving the left headlight will flicker then go off after about 5 mins of driving. Then i have to turn the headlights off for about 15 secs and turn them back on. But if i turn the stereo off completely and drive the headlight wont turn off or flicker. Just wondering if anyone knows what the problem could be. Its really a pain in the ass. Thanks
Old Apr 14, 2009 | 08:42 AM
6spdtl-s's Avatar
Nismo TL yo!
could be a power consumption issue. Might want to consider a capacitor for the amps or a higher output pulley for the alternator. Maybe theres a loose connection somewhere? Do your interior lights dim at all? How much power are you running to your amps?
Old Apr 14, 2009 | 09:59 AM
ankur914's Avatar
Yup..it sounds like your current electrical setup cant keep up with the power demands of your audio system. This happened to a kid in our high school autos class....A proper capicitor rectified the situation.
Old Apr 14, 2009 | 10:18 AM
Dgreen06TL's Avatar
8th Gear
Yeah im hoping just a loose wire but not sure yet. The 4-channel is 500 watts and the Mono to the sub is 1000w. Interior lights dont dim nor do the headlights when its turned up, thats the only reason why i wouldnt think the power supply, the light just goes out. I got an optima battery powering the car.....i dont know if that would help at all. How much does a capacitor??
Old Apr 14, 2009 | 11:12 AM
Tripnbeats's Avatar
probably something loose under the hood on the headlight end or power issue...i have never heard of a system not enabling or making the HIDs shut off. i had an issue like that but it was a bad ballast it would go off and id turn it off n turn it back on and then it would tay on like oh its good and shut off again....i had the ballast and bulb changed
Old Apr 14, 2009 | 01:00 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Old Apr 14, 2009 | 01:01 PM
6spdtl-s's Avatar
Nismo TL yo!
the headlights wont dim because they run off of the ballasts. However, if the interior lights arent diming then I would say its a loose connection to your headlight.
Old Apr 14, 2009 | 02:22 PM
KaMLuNg's Avatar
+1 on this right here...
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
kb1rl
Sep 30, 2015 10:17 AM
thegipper
Sep 28, 2015 01:01 PM
h22lude
Sep 27, 2015 06:22 PM
