Strange problem, LED related?
Old Apr 18, 2008 | 10:22 PM
evnash's Avatar
EVNS TL
today the indicator for my trunk open wouldnt go off. i figured the trunk switch was bad but then i noticed i didnt have any interior lights. turns out the 7.5 amp fuse in slot #6 was blown. I replaced it with another 7.5 and its been working fine for a while now. trunk indicator went off.
#1 why would the trunk open indicator be affected by a blow interior light fuse?
#2. fuses blow for a reason. ive replaced all my interior bulbs with leds, could the leds be pulling just a litte bit more current than the stock blubs? i would think it the other way around.
any thoughts?
Old Apr 18, 2008 | 10:54 PM
csmeance's Avatar
did you recently install the LEDs? You may have reversed the polarity on one or have a loose one causing a short.
Old Apr 18, 2008 | 11:00 PM
Bearcat94's Avatar
AZ Community Team
I shorted mine while installing and LED in the trunk or the reverse lights.
My guess is that the blown fuse effected the "trunk closed" switch, so with the switch not working, the car thougt the trunk was unlatched.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
jblessing
Aug 8, 2018 09:43 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
HeloDown
Sep 8, 2015 06:51 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
