Strange A/C noise fixed!
Three weeks ago, I purchased my beautiful 2005 TL which was a significant upgrade from my rusty 1994 Honda Accord. For the first two weeks we were like new lovers and everything was new and exciting, then my baby developed a strange quirk and I feared that the honeymoon was over.
When I went around a curve (only to the left) there was a strange rushing liquid noise on the passenger side, sort of like what you would hear if you partially closed a faucet and the velocity of the water would increase. I narrowed it down to the A/C system by turning it off partway around a curve and confirming that the noise stopped. I called my friend (a Honda mechanic) and described the problem. He suggested a plugged A/C drain hose so I took a look under the car. Right away I noticed a shiny chrome thing that looked out of place, hanging down in about the middle of the underbody. I grabbed it and gently pulled it free, uncorking a gallon or so of condensate from the A/C drain. It turned out to be an extension from a 3/8" socket set that someone had inserted into the drain hose. My assumption is that when the mechanic was doing the safety certification before I bought the car, he was getting dripped on and temporarily plugged the hose with the nearest tool. The noise I noticed was likely the water getting picked up by the A/C fan when I went around a corner.
The love affair is on again and I now have an extra extension for my tool box!
PCM full of water, yummy
Is this something you think could be likely and if so, is there a preventative step I could take? Do you recommend returning to the dealer to get a record of this for future reference? Any advice is appreciated.
hates potatoville
As soon as the weather gets cooler, I will be spending some time in the garage looking where I can drill an overflow drain hole for mine. Routed away from the PCM. No doubt, another crazy mod from Inaccurate.....
Let me know what you find out, I plan on doing something similiar. Don't want the headaches that I'm still having from my PCM filling up with water. It is a huge PITA.
Besides, Blokhead has scared the bejeezus out of all of us.
It's been unusually cool in the northeast this summer until recently. Now it's warmed up and people are running their air conditioners. In September and October we'll see a lot of posts about burned out switchback bulbs because the days get shorter, people turn on their headlights, and notice that the buttons don't light.
Yes, definitely take it back to the dealer with the extension and get it documented. Have them check the PCM for signs of corrosion or water intrusion. Also, if this was a CPO car, I'd call Acura Client Services and get it documented with them.
snorf
11-04-2019 06:44 AM
