Steering Wheel Vibration at Idle
Old Jan 10, 2010 | 03:57 PM
VQPower37's Avatar
Hi All,
I have a problem with my 07 type S. I have a pronounced vibration in my steering wheel when I come to a complete stop at a traffic light.
I did a search on the forum and have narrowed it down to a few things possibly.
Dirty air filter? Which I'm not sure is really the problem because I had my B1 done recently and the dealership didn't mention anything.
Broken motor mount? My car has about 49k miles on it ... is this even possible to break so soon? And will it be covered under warranty if it is broken. I have yet to get under the car and see if any of them are leaking its just so cold I dont feel like laying on the garage floor.
Very low idle? I would think in a car like the TL the idle is managed by a computer but I dont even know how to check something like this. It seems to be idling at the same rpm that it use to when the car was new.
Any input on what you guys think the problem is, and what I should go about doing to fix this. Please let me know.
Thanks in advance.
Old Jan 10, 2010 | 06:01 PM
vovka2007's Avatar
Most likely the Hydraulic motor mount. Honda's are known for mounts to go out.
Old Jan 10, 2010 | 06:11 PM
VQPower37's Avatar
Thank you for the response vovka, I was leaning towards the mount as well ... would something like this be covered under warranty as I feel that 48k miles is very low for a mount to go. From my previous experience with Honda, I feel that most mounts tend to fail around 100k
Old Jan 10, 2010 | 06:15 PM
crazyasiantl's Avatar
my buddy had the same problem on his 06 TSX. turned out to be two bad mounts
Old Jan 10, 2010 | 06:24 PM
VQPower37's Avatar
Ok thanks for the response crazyasiantl ... I got two votes for MM, does anyone have a similar experience?
Old Jan 10, 2010 | 08:22 PM
VQPower37's Avatar
Are motor mounts covered under the original manufacturers warranty?
Old Jan 10, 2010 | 09:47 PM
libert69's Avatar
18psi
yes. motor mounts are also covered under the acura car extended warranty. i had 2 replaced under the extended warranty
Old Jan 12, 2010 | 10:43 AM
Majofo's Avatar
If it is a motor mount I put my money on the rear mount. OP do you notice the RPM's fluctuating at all in idle? If so, it could be a vac leak.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
