steering wheel shaking, balance or alignment problem?
Old Apr 18, 2009 | 07:25 AM
eso.teric's Avatar
Hi, recently my steering wheel starting to shake at low speed (20-40mph), once i hit 60 the shaking/rattle stops. I just want to know if its a balance issue or an alignment problem. Thanks in advance.
Old Apr 18, 2009 | 08:37 AM
Jesstzn's Avatar
Could be either .. but the rattle is what would make me nervous .. get them both checked and the suspension checked too.
If you swap one front wheel to the same side on the back then drive it you can tell if its that wheel or not ,, then try the front to back on the other side.
If still not then its suspension or alignment. Usually alignment doesn't cause a shake.
Old Apr 18, 2009 | 09:31 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
most certainly might be either the wheels require rebalancing or check your sidewalls you might have a bubble
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
