Steering Wheel Cable Reel Rewind>?
Help...does anybody have the procedure for rewinding the steering wheel cable reel...when I was installing the a-spec steering wheel tonight....during removal of the old wheel...the cable reel unwound and came out with the wheel and I need the procedure to rewind it properly to get the new wheel on....
I couldn't find a procedure in the service manual for rewinding the cable reel.
When installing the steering wheel, it says to make sure the front wheels are aligned straight ahead, and then center the cable reel by first rotating it clockwise until it stops, and then rotate it counterclockwise about 3 full turns. The arrow on the cable reel label point should point straight up.
Registered User
be very careful when turning the cable reel, if you turn it too many times the cable with snap, and you can not repair it
if you open the plastic it's as good as garbage
it looks like this inside
![](http://digitalww.com/images/lilli_ribbon_opposite_2.jpg)
End result....great install after all was said and done. Can be done fairly easy, so long as you follow directions closely AND DONT NEST THE SPOOL WIRES! If you are very slow about the wheel removal...that shouldnt be a prob though as the spool wires are encased in a plastic case. There are two protruding tabs that go into the back of the wheel from that case and in my case it brought the front of the spool off too, but if you were slower and didnt YANK it like I did (pay the $15 for a remover) this should not be a problem. Install should have been 1.0 hours to 1.5 hours.....turned into an all night project for me cause I duped it and had to figure out how to rewind that damn spool...which ate up all the time...later it got....worse your mind worked! Finally got it though....would recommend to anybody with A-spec kit installed.....JUST BE VERY SLOW WHEN YOU PULL THE ACTUAL STEERING WHEEL OFF and watch the plastic case top below as this is where the wire reel is that can come unspooled. Thanks for the efforts Ron! Much appreciated!
Originally Posted by 05ssm
Do you know if the horn panel and the silver pieces surrounding the steering wheel buttons can be removed?
Thank you,
Terry
Thank you,
Terry
![](http://www.acuraoemparts.com/delray/jsp/catimgs/14sep401_b3110.gif)
B A N N E D
Thank you,
Terry
Thank you,
Terry
![Red face](https://acurazine.com/forums/images/icons/icon11.gif)
Thank you,
Terry
Thank you,
Terry
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
B A N N E D
Originally Posted by TampaMike
Nope. My plastic chrome 'A' badge has given up it's plastichrome and is now white plastic.
My dealer is replacing the entire airbag assembly! "Lay off the horn!" he says. Little does he know it is really due to my acidic alien blood. ![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![](http://fla.fg-a.com/Alien03a.gif)
Mike explaining to the dealer about his horn?
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
Also, have any pics. Always like to see these things in other peoples cars..
B A N N E D
Originally Posted by SilverStoneTTL
wow, i think I would freak out and my parents would kill me if something like that happened to me and I couldnt get it fixed. Whats the tool your talking about? Your story makes me not want to ever attempt this.
So, in trying to figure out where the rattle is coming from in the steering wheel/column area, I removed the airbag/horn and the steering column cover. Nothing was noticably loose. Even checked the buttons on the steering wheel. I believe that the rattling is coming from the cable assembly.
Michael Benz, when you worked on your steering wheel, do you think there is any way to get the cable assembly to be quiet?
Thank you,
Terry
Thank you,
Terry
B A N N E D
Thank you,
Terry
Thank you,
Terry
Michael B
rockyboy
12-06-2022 02:29 PM
