Steering Vibration - New Wheels
Old Aug 3, 2011 | 02:00 PM
kcook73's Avatar
I purchase an 05 TL 6-speed with 80k miles. It had steering wheel vibration at 70mph+ (tires less than 20% worn). I rotated tires - didn't fix. I had tires balanced - three of the four wheels were bent. I installed four new wheels - the vibration is a bit better, but still there at high speeds. Could the rotors (it has the Brembo brakes) be out-of-balance at 80k miles? I am not getting any pulsation when braking at any speeds.
Thanks for any help / suggestions.
Kevin
Old Aug 3, 2011 | 03:20 PM
Turbonut's Avatar
Needs to be balanced. Look for a Hunter machine:
http://www.gsp9700.com/search/findgsp9700.cfm
Old Aug 3, 2011 | 04:02 PM
BukvaMan's Avatar
maybe due to the damaged wheels the tires have an uneven tread and even though you balanced them with the new wheels, that slight unevenness will show its self especially at higher speeds ... just a thought. Maybe you should give it some time to work its self out.
Old Aug 3, 2011 | 06:05 PM
dzionny_dzionassi's Avatar
or maybe you are just like me and will never find solution for your problem.... Acuras like to vibrate for no reason
Old Aug 3, 2011 | 07:21 PM
BukvaMan's Avatar
Thats also very true
Old Aug 3, 2011 | 07:51 PM
rhafikjaan's Avatar
did you install oem wheels?
Old Aug 3, 2011 | 08:04 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Definitely recommend trying this.
Old Aug 3, 2011 | 09:04 PM
usmarinedelta's Avatar
Same situation I had, check your lower control arm bushings, make sure lug nuts are torqued to spec, and make sure your psi are all the same for the tires. Also give it some time until tires even out.
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
nishant11
Sep 2, 2015 10:34 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
