Starting trouble
Old Sep 21, 2017 | 11:59 PM
datboykam 777's Avatar
4th Gear
Starting trouble
Help car won't start I have an 05 tl I got into it this morning an the steering wheel was extremely stiff not only that the brake pedel was too which was completely strange I'm pretty sure it's not the starter I can crank my key but only hear an odd sound that seems to be coming from the steering wheel not sure if I should tow it to the shop of call a locksmith anyone ever experienced this mishap
Old Sep 22, 2017 | 08:05 AM
Turbonut's Avatar
Confused, but when you "crank the key" is the engine turning over or not?
Old Sep 22, 2017 | 08:09 AM
4th Gear
No
No nothing happens expect the dash lighting up sometimes a buzzing sound that sounds like it's coming from the steering wheel🤔🤔🤔
Old Sep 22, 2017 | 08:32 AM
nfnsquared's Avatar
Bad ignition switch or bad starter.
Ignition switch is an easy DIY and about $40. See this thread, posts #31 and #33:
https://acurazine.com/forums/3g-tl-p...-sound-795411/
Old Sep 22, 2017 | 08:40 AM
4th Gear
Same
That's kinda what I was thinking as well 🙏
Old Sep 27, 2017 | 06:05 AM
DMZ's Avatar
DMZ
Head a da Family
Have you checked the + battery cable? At this age it might be corroded internally to the point where it can no longer conduct enough juice to start the car.
Old Sep 27, 2017 | 06:07 AM
4th Gear
Yupp
Yeah the batter an cables are relatively new shop said it was the starter should have her back Friday thank you guys tho.
Old Sep 27, 2017 | 10:37 AM
peter6's Avatar
Friday? It's one hour job
