starting issue
Old May 29, 2024 | 10:18 PM
xedap1998's Avatar
starting issue
I have this issue that i dont know where to look. Sometime when it start my TL it would click click and then the car loose power completely. The only way to get the power back is to disconnect the negative cable. When i disconnect the negative cable i can hear the start disengage
I have replaced the ignition switch fairly recent but the issue rename. The starter have been replaced a year ago or so but i dont recall if this is a new issue or an old issue. I think the issue might be with the rebuild starter
Please help
Old May 29, 2024 | 10:44 PM
So replace the starter!
Old May 30, 2024 | 09:46 AM
Jackass's Avatar
If you lose all power, you have a power issue. Check your battery cables. You either have a loose connection or a corroded cable. This is assuming you say the car loses all power, you mean all of the car, no lights, no dash, no nothing until you mess with the battery cables.
Old May 30, 2024 | 05:19 PM
xedap1998's Avatar
This is exactly the issue
I have battery quick connect /disconnect due to blue tooth battery drain, but i already fixed the battery drained issue. It turned out that the quick connect was loose at a place where it connect
Ancientsanskrit
Feb 15, 2023 02:26 PM
animalin5tinct
Aug 17, 2019 05:24 PM
thamind
Dec 15, 2018 08:27 PM
iceman601
Jan 19, 2011 06:00 PM
herCLS
Aug 6, 2008 09:23 AM
