SRS DTC Code 4-1
Old Aug 20, 2013 | 02:48 PM
05SSMTL's Avatar
SRS DTC Code 4-1
Need some help- Airbag light is on- tried to reset it, but came back on. I jumped the connectors and the DTC code came back as 4-1, which I know on Honda's points to passenger Seat Belt Tensioner- Car has not been in an accident. When I look up codes for 05, 4-1 isn't on there. Is it a valid code for the 05? I changed the seat belt tensioner, but I still have the light on. I tested both tensioners for resistance and they both came up with 2.2 ohms, which is what it should be. Any ideas? Need a sticker....appreciate any help.
Old Aug 20, 2013 | 06:35 PM
JJH's Avatar
JJH
You need to reset the light.
http://forums.clubrsx.com/showthread...&highlight=srs
Old Aug 21, 2013 | 12:46 AM
paperboy42190's Avatar
might need to replace the seat belt buckle...i heard some ppl with 05 TL's had that issue
Old Aug 21, 2013 | 12:58 AM
csmeance's Avatar
According to the service manual the DTC code is 4 digits for the SRS system, I'll upload the pictures. Also I checked the wiring diagram for the whole SRS system and the only connection it has to the tensioner/seatbelt is this:
Old Aug 21, 2013 | 06:49 AM
05SSMTL's Avatar
Thanks for uploading the diagrams- I have been looking for that. When I jumped the 4 & 9 connection on the OBDII plug, the airbag light blinked 4 long, and then 1 short. That is the only code it is throwing. It repeats itself after that.
JJH- thanks for the link, but I have reset the system a few times. It goes off, but the next time the car starts and runs through the system check, it pops back on.
I guess I will need to check the wiring. It is really frustrating. I unplugged the passenger seat buckle, and it didn't throw another code- only thing that happened was the Passenger Airbag Off Light stayed on. Once I plugged it back in, the Passenger light went off.
Old Aug 21, 2013 | 11:19 AM
JJH's Avatar
JJH
In to figure it out. I've got two different TLs right now both throwing 8-1 codes after doing my interior swap which involved swapping the seats. I also swapped the OPDS modules though so my car should have never really detected anything at all different because the battery was unhooked the whole time.
Old Aug 21, 2013 | 12:41 PM
05SSMTL's Avatar
so just stopped by auto body place. they read my code for free. I don't get it- when i read the code with the jumper it came back 4 long blinks, 1 short blink. when they read it with a reader, it came back saying my front impact sensor and passenger seat buckle are causing the issues. Car has not been in a crash so don't know how both went.
Seat buckle has a lifetime warranty?
Jamus22
Jun 11, 2023 10:08 AM
brboy
Oct 5, 2015 11:34 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
