Squealing brakes at cold start up
Old Nov 9, 2011 | 11:36 PM
Aretardedorange's Avatar
A6 and TL
The brakes on my 2008 Acura TL which has 26k miles squeal during the first few stops in the morning. The noise goes away after the car warms up. Just started happening. The squealing is very noticeable and embarrassing. What can the problem be?
Old Nov 11, 2011 | 05:39 PM
spaceboy's Avatar
it happens to a lot of the TLs out there...u ain't alone!!!
Old Nov 11, 2011 | 06:02 PM
lsimmons's Avatar
Mine does the exact same thing. I was also wondering about this..... Guess it's normal.
Old Nov 11, 2011 | 08:25 PM
whudini3000's Avatar
I have the exact same problem... I'm going to clean the front brakes this weekend. I hope this helps.
Old Nov 12, 2011 | 09:44 AM
ez12a's Avatar
the overexplainer
with high performance brakes, squeal is normal, guys, as long as it quiets down after a few stops.
it's also winter, so moisture and crap get on the brake pad/disc.
Old Nov 12, 2011 | 09:50 AM
Maybe so, but its embarrassing
When driving a luxury brand esp. when it echos through the parking garage
Old Nov 15, 2011 | 11:54 AM
spaceboy's Avatar
i kinda cleaned the brake with WD-40 the other day cuz i thought maybe it's because it's dirty, for some reason I am not hearing the squeaking as often compare to before...maybe it's just the psychological thingie???
Old Nov 15, 2011 | 12:28 PM
ez12a's Avatar
the overexplainer
you put a lubricant on your brake pad/disc...?
if so you need to change your pads and clean the disc with brake cleaner.
Old Nov 15, 2011 | 09:39 PM
WD-40? uh oh.
Old Nov 15, 2011 | 09:53 PM
SpiderX1016's Avatar
Mine squeals when they're cold. Doesn't bother me.
Lol, I hope you didn't spray that stuff on the pad surface/rotors.
Old Nov 15, 2011 | 11:25 PM
spaceboy's Avatar
I did it with the wheels on, didn't spray too much. drove for 2 days until i realized it was a wrong move, took it a my friend's shop today, he took off the rotor and pad and deep cleaned it with brake cleaner, he didn't bother to ask me to replace the pads cuz he said i didn't need to, most of the WD-40 were burned off before i was there today.......=(
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
2012wagon
Sep 29, 2015 04:21 PM
dlknight
Sep 3, 2015 07:54 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
