Squealing brakes - 2005 5AT
AVB for President!
Recently my brakes started squealing with modest to heavy pressure on the brake pedal (say, slowing down from 35mph to 0 in 50-100 feet, which isn't terribly hard). It seems that light to moderate pressure does not cause any audible squealing, but this is the first time I've heard the squealing.
I don't think the pads are worn out because I just got my B service two months ago and they checked them. There was plenty of padding left.
I've got 13,500 miles on it. Any ideas? (And no, I do not have an MT, so Brembos squealing is a whole different story that's not related to my case)
AVB for President!
I got an appointment with the dealership next Wednesday for this issue and others (2 rattles which I've nailed the location and cause, and also a strange sound coming from rolling up the passenger side window). I'll let you guys know how it turns out!
9.5+10.5 22m=Hella Flush
Mine started squeeling in the fronts pretty bad and I brought it back to Acura and they smoothed out the break disc at no charge. The squeel went away and came back again after 1wk of driving. I think it is the break pads Acura is using so next time I bring my car in I am planning to get them to change it.
I have the same problem with the sqeaking noise in the mornings when I first start to leave. I'm probably breaking under 5mph and then it'll make the noise and it'll go away later. So I just had my B service done and they said my pads are in good shape but it's still making noise. It is annoying, but I guess when it's time to replace my pads I will probably replace the pads to another manufacturer. The break dust can cause the noise, but it will come back again later. Maybe WD-40 might get the sqeak out, but I don't know if that will cause any damage to the disc.
If anyone else knows a different solution to this problem, please let me know.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
