Squeaky clutch
Hi,
I just noticed today that when I press in and release my clutch pedal, it sounds like a plastic stretch sound is coming from the clutch. Any suggestions of what it can be? |
Um, what kind of car, how much mileage on said clutch, and how do you drive? Might get more of a response.
I just replaced the clutch/flywheel less than 500 miles. 2004 Acura TL. 189k. No aggressive driving. Always shift between 3k to 4k.
Throw out bearing needing grease? Linkage needing some attention? Any slipping at all?
This might be better off in the 2G TL forum. |
agreed, throwout bearing
No slipping so far. What kind of grease do you recommend?
it's usually solvable by replacing the throw out bearing and or the seal.
(Post 16409389)
Is the sound part of the pedal movement? Or part of the clutch engagement? Does it make the same sound with the engine off?
Originally Posted by dea7hr0w
(Post 16408937)
Engine not running: old pressure plate, clutch pedal and return spring, clutch master and/or slave cylinder (if you have a hydraulic actuated clutch). Engine running: same as above, clutch release bearing. Normally when you do a clutch, you do it all. Main seal, transmission input shaft seal, clutch release bearing, clutch assembly. Well I do anyway. |
Engine is off and only occurs when I press in (squeak sound) then release (squeak sound). I am hoping to narrow it down to "clutch pedal and return spring, clutch master and/or slave cylinder". The sound resembles plastic stretching.
the squeaking sound you described actually come from the pedal cylinder, you can try to apply lubrication like silicon spray or replace with a new one. Mine squeak only because I put 75 miles every other month lol.
Originally Posted by Tech
(Post 16411181)
