Squeaking, Squeaking and More Squeaking
Old 08-06-2010, 10:33 AM
5th Gear
dysfunctionalexcess's Avatar
Greetings everyone. I have an 06' TL with 20k miles and the technology package. The dealership replaced all the speakers due to a major squeaking issue, (especially the front center speaker) and now the visors and the map pockets in the doors are squeaking. Anyone have any suggestions? Is this a common problem?
Thanks for your help.
Old 08-06-2010, 11:42 AM
ScoobyZINE
AMUA6's Avatar
@ the low mileage for an '06. But I've never heard of the visors nor map pockets EVER squeaking.
Old 08-06-2010, 12:19 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
ck the DIY section for noises repair, lots of tricks in there
DO you crank the stereo with the windows cloased?
that will create a massive air pressure movement in an enclosed space,
which could lead to vibrations loosening screws and worse
If you do that:
try opening the sunroof or rear windows a bit- you will find the sound may be better quality at higher volumes
Watch the rear glass on any car with the bass thumpin at a stoplight- you can see the entire trunk lid and window glass moving~
Old 08-06-2010, 12:20 PM
01tl4tl's Avatar
you tried tightening the visor screws and made sure the door panel clips are in place and the screws in door panels are in tight?
dealer may have missed a few during speaker swap~ stranger things have happened
Old 08-08-2010, 01:28 PM
blueridger's Avatar
There are many sources of noise in the headliner/visor area. Mine was making snap, crackle, pop noises most of the time. I lowered the front-center part of my headliner ('07) last weekend and put adhesive felt on everything that looked like it might make noise. (Wires, connectors, edge of roof console, etc.) There are big improvements, but I'm not done yet. Next biggest source of noise appears to be the 4 plastic headliner clips on the forward side of the sunroof opening. I'm not sure how I'm going to solve it just yet.
For those who are interested in tackling this DIY, I followed the instructions in the service manual, also available in post 19 in this thread.
Old 08-10-2010, 07:11 AM
5th Gear
Thank You
Thanks for all the advice everyone - I found that opening the rear windows a bit helps, as I crank my music every time I am in the car, and I did tighten the visor screws, seems to be working so far. =-)
Old 08-10-2010, 10:59 AM
01tl4tl's Avatar
ahhh the pressure dynamics at work!
kmawani
02-08-2023 05:09 AM
2012wagon
09-29-2015 04:21 PM
njresendez
09-21-2015 11:23 AM
forrie
09-15-2015 09:57 AM
jliu6789
09-08-2015 08:02 PM
Quick Reply: Squeaking, Squeaking and More Squeaking
