A-Spec sides a bit loose, normal?
Old Apr 21, 2014 | 02:22 AM
chackhou's Avatar
Do you guys have a wobble in the middle where the two pieces connect? My A-Spec sides seem a bit loose so I'm not sure if they were installed properly.
Old Apr 21, 2014 | 03:38 AM
paperboy42190's Avatar
There are supposed to be clips on the bottom. Check those
Old Apr 21, 2014 | 01:24 PM
erdoc48's Avatar
06 Anthracite TL
They can feel loose. They can also rattle like mad! They're very easy to remove and put some vinyl 'camper tape' to replace the thin spacers they came with. In this way, you'll stiffen them up (they will feel more secure) and if they're rattling, it'll eliminate that as well.
Old Apr 21, 2014 | 03:39 PM
Vlad_Type_S's Avatar
Registered Bike Offender
There is a clip underneath that joins the two pieces, and then three clips that connect them to the body, 4 screws in each fender too. See if any of these are missing. Otherwise, if I were you, I would remove them completely and see what's missing. The instructions are basically the same as these except there is one additional clip that holds the two pieces together right in the middle. http://techinfo.honda.com/rjanisis/pubs/AI/BII37365.pdf
Tightening it up with some spacers is a great idea, too.
Old Apr 21, 2014 | 04:09 PM
chackhou's Avatar
thanks for the info!
marcelft
Jul 10, 2018 06:17 PM
01CLOwner
Oct 9, 2015 01:07 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
PortlandRL
Sep 14, 2015 12:01 PM
JnC
Sep 11, 2015 06:06 AM
