Spark plug question-blah blah blah..
LowNslowTL
Yay another spark plug question! I am replacing mine today, but i dont have a torque wrench that reads below 25 foot pounds.. i just cant justify going out and buying one to torque my plugs when ive never torqued plugs before. Question is, how necessary do you guys find it to tq them down to 13 ft pds, or would i be good just getting them snug like you would any other plug job?
Advice on spark plug installation and torque.
Last night I replaced the plugs on my 06 RL. It took a few hours since the back ones are a pain to get to. Need a universal joint to get the spark plug socket into the hole. I used the NGK Iridium plugs and they recommend not using antiseize. If I had to do it over again I would use a little though. They were tough to get turning. Those plugs have a washer which has to be crushed before the final torque is applied. I found information that the plugs have to be turned just a little past 1/2 turn (beyond hand tight). If you use antiseize and hand tighten, then just turn a bit past 1/2 turn and you will feel the resistance increase dramatically. In my experience if you just get it past that point (where the resistance has spiked) you will be at the correct torque.
LowNslowTL
FYI, I used SM spec (13 ft-lbs) with A-S and the plugs are fine after 30K miles. I wouldn't stress over it.
nismopowerdqg (04-18-2013)
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
