So I got a flat...
So I got a flat...
After the East Coast Honda Meet, I decided to go chill over at my friends place. I always told her that her driveway is some garbage. It's dirt, rocks, pebbles and two cement pieces you have to drive on. On top of that, the driveway is down hill!! We've known each other for +10 yrs and I haven't had any problems before.
Long story short. I got a flat and realized it as soon as I got off her driveway. Pulled back in and was like forget it. Gotta put a donut on and I'll worry about it later.
I ended up bending the jack...Bent my side skirt outward...It's almost midnight. Can't see nothing and IDK how that happened?
Here's my flat...
Now as I jacked the car up with another jack. My brother realizes that this doesn't look like the other side. IDK what exactly this is, but it looks bent outta shape compared to the passenger side. Can yal HELP me!!
Here's my flat...
Yeah that sucks, you should really find out where the jack points are to avoid further Fing' up your ride.
I've had 2 flats in 10k miles...both screws. One was to close to the sidewall, had the tire replaced the second one i had got fixed with a plug.
Both times i was hours away from home and was glad i didn't remove the spare because fix-a-flat wouldn't of helped.
Its hard to tell whats wrong with your car from the pictures, but i don't think you could of caused to much damage by jacking up you car.
That's the upper control arm, I don't see anything wrong with it to be honest with ya. If it was bent your alignment would be off and you would be able to notice something is up when one wheel sits different from the other. There are pinch welds under the side of the car for lifting. There are 4 main lift points (2x each side) By lifting the car on a flat, smooth surface in the correct lift points I don't see how any damage would have been done. It seems that you lifted before the pin welds thus damaging your side skirts. Those factory jacks are designed to lift up the vehicle without bending or breaking.
It must be flat season, I hit a chuckhole the other day and popped a tire, bent the wheel a little bit too. First time I had jacked the TL up, was pretty easy to match up where the factory jack went under the car. In fact, it was the easiest tire I think I can remember ever changing.
I got some Sumitomos on there now, not too happy with them. Maybe they didn't balance them right, but they seem to make the ride a lot rougher, the car shakes a little too much now and I have new rattles that I never noticed before. Ah well, they were about 1/3 the cost of the OEM tires that were on the car when I got it.
Thanks for the comments guys.
This was my first flat EVER!! lol + I'm a grl. ( Not using that as an excuse. ) But all is well now. I guess I was just tired and the situation just made it worst. Got the spare on and drove it down the street where they inspected the tire. Glad they were open today!! Got the tire plugged and super happy that I was on the spare for less than 2 minutes!!
Not to give you bad criticism but isn't plugging a tire bad for it? How much would a new tire have cost? There is nothing wrong with your control arm, as pointed in the picture. Like said above, there are 4 lift points. Like WDP said, you must not have been on the lift point. I wouldn't worry about it, since it's under the car
What is showing in the picture is the upper control arm that is the big horse shoe that you see, and what is in the center where the flash is shining is the upper ball joint, it looks good from the picture. When you decide to drop your car and you realize that you need a front camber kit you will replace the upper ball joint that will allow you adjust the camber.
ME TOO!!
I will definitely look into that. But I know for sure that next time it won't be as hard!!
