Snapped off top bolts holding rear license plate =(
Hey,
Today I decided to wash the car.
I have a license plate cover and saw it with dirty behind it, so I decided to remove it to clean it.
Top two bolts are rusted as hell, bottom bolts look brand new.
As you can see:
![](http://farm5.static.flickr.com/4098/4939784353_40b793d54f_z.jpg)
Bottom bolts came out no problem.
Then I worked on the top bolts.
They were hard to loosen.
I got a few rotations and the bolt head snapped off!![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Then I did the second one and it snapped off too!
I cleaned the plate cover and plate anywho, and stuck it back on using the two bottom screws.
Any tips on removing the screws that snapped off?
I can grip them using pliers, but when I try to turn it, I hear a "spring".
Anyone help?
Thanks =)
As you can see:
Anyone help?
Thanks =)
Spray them with PB Blaster and use vise-grips, but turn them in slightly before backing out, then go a little at a time, in then out. When all else fails, drill through the center and use an easyout with a lot of lubricant. Cover the painted areas when using the lube.
Replace with stainless steel fasteners.
I tried using vise grips but I heard a springy sound.
It was scary and weird so I stopped.
Might go buy PB Blaster tommorow =)
Can I get "stainless steel fasteners" anywhere?
I might drive down to my local Acura dealer (45 minutes away) and just ask them to fix this problem (while I buy some parts heheh).
I assume they can be purchased at most auto parts stores and you can always use neverseize on the theads of the new bolt ust as a precaution.
cycdaniel
12-17-2019 10:58 AM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
