Slight draft coming from airbag???
is in Honda heaven
1 Post
Has anyone else noticed a slight draft coming from the drivers side airbag while driving? I haven't noticed it but my wife who drives 95% of the time said something about it the other day. I chuckled but figured I'd ask because anytime she's noticed small stuff like this and I disregarded it there actually ended up being an issue.
Your Friendly Canadian
Received 1,492 Likes
Could be air blowing through the driver's side vent My Accord does it. Try driving with the recirculation on, see if it makes a difference.
Registered but harmless
Received 1,148 Likes
Air could be coming from the dash vents or the windshield defrost vents.
The dash vents can be repositioned to direct air away from the driver to see if that stops the draft.
Switch to dash or footwell vents only mode to see if the air is coming through the defrost vents.
The "Recirculate" function will not stop the air flow if the climate control fan is on-- the fan will just blow air from inside instead of outside.
AM Flakes still Drippin'
^ I think Aman is saying to turn off the air but leave the "recirculate" on. In the 2nd gen, this stops any type of draft through the vents while the air is off.
:yup: I meant recirculate on with climate control off. This should stop any air flow.
marcelft
07-10-2018 06:17 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
nanos
11-12-2015 08:41 PM
