Slight bucking upon acceleration and deceleration
Old Nov 2, 2010 | 08:54 PM
NJDEE's Avatar
Over the past 2-3 months I've been noticing a very slight bucking upon acceleration and deceleration.. both at low speeds (30mph and below). Tonight however the bucking was a bit more jarring. As I proceeded beyond a stop sign it was very noticeable. I can't replicate this on my own, it just happens on it's on. It happens at all different times and under different conditions (weather, temperature, etc etc).
The car is an 08 Base TL, Auto. Less then 35k miles. I'm the only owner.
Thanks.
Old Nov 3, 2010 | 06:45 AM
lazytik's Avatar
Happens to me too, think it's normal.
Old Nov 3, 2010 | 06:54 AM
vuuha05's Avatar
Yeah I've been experiencing the same thing with my TL '05, but I have around 80k miles.
Old Nov 3, 2010 | 07:15 AM
VQPower37's Avatar
if its on a hill its the grade logic i believe ... i have the same "issue" with my 07 type S ... 76k miles
Old Nov 3, 2010 | 08:37 PM
csmeance's Avatar
is the "bucking" happening when the car is shifting or while engaged in gear?
Old Nov 3, 2010 | 10:49 PM
NJDEE's Avatar
Good question.. I'm not 100% sure but I'm going to say while engaged.
Old Nov 4, 2010 | 03:37 PM
D's Up's Avatar
9 mpg.
Going by memory, I'm going to say that if you drive normally the TL would be shifting into third around ~30mph. So if it bucks around there or while braking/decelerating, it's probably your pressure switch. Mine does it too.
How do you fix it?
- 3x3 Redline ATF
- Switch out the 3rd and 4th gear pressure switches.
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
