Slight bucking upon acceleration and deceleration
Over the past 2-3 months I've been noticing a very slight bucking upon acceleration and deceleration.. both at low speeds (30mph and below). Tonight however the bucking was a bit more jarring. As I proceeded beyond a stop sign it was very noticeable. I can't replicate this on my own, it just happens on it's on. It happens at all different times and under different conditions (weather, temperature, etc etc).
The car is an 08 Base TL, Auto. Less then 35k miles. I'm the only owner.
Thanks.
Thanks.
is the "bucking" happening when the car is shifting or while engaged in gear?
9 mpg.
Going by memory, I'm going to say that if you drive normally the TL would be shifting into third around ~30mph. So if it bucks around there or while braking/decelerating, it's probably your pressure switch. Mine does it too.
How do you fix it?
- 3x3 Redline ATF
- Switch out the 3rd and 4th gear pressure switches.
How do you fix it?
- 3x3 Redline ATF
DerrickW
11-15-2015 05:52 PM
1999, 2008, acceleration, accord, acura, braking, bucking, car, cl, deaccelerating, deceleration, honda, rdx, shift, sound
