Side View Mirrors--Problem
My side view mirrors will no long adjust down for backing up. I put the car from reverse to drive several times but nothing happens. I just noticed this today as I left work. Has anyone else had this problem? Is there anything else I should try before taking it to the service department?
AZ Community Team
Received 7,771 Likes
Make sure the mirror selector switch is either "Left" or "Right" - that determines which mirror tilts down. If the switch is in the center, neither mirror tilts.
Originally Posted by BLACKURA_NY
^basically, or a fuse
do your mirror heaters turn on and off? (lil yellow light)
2006 Acura TL
Oderint dum metuant.
I had the same problem...it's a dealer/warranty fix. Something is bad with a motor or switch (I forget what). My left one was bad, but Hendrick tested the right one while they had it and said it was bad, too. The replaced both under warranty.
2006 Acura TL
GOLDEN NUGGET
Does anyone know if this is covered by the extended warranty I purchased thru Honda when I purchased the car. I've had other work done during the warranty. I'm assuming it's covered...I have the 100,000 mile extended warranty.
navtool.com
31
11-16-2015 08:30 PM
