Side view mirror jitters when moving up and down
Old Jun 5, 2010 | 10:06 PM
Project X's Avatar
the side view mirrors on my tl jitters when moving up and down while the car is being reversed. i heard this happens in cold climates but we have 90 degree temp now and i have this issue and noticed it recently.
Old Jun 5, 2010 | 10:11 PM
ThatOneFuriousTL's Avatar
idk mine did the same once or twice... it almost sounded like it was clicking or it got off track or something... then i put it in drive, then back to reverse and it went away... i live in FL and it happed when it was hot outside so idk about the cold weather... i would say just be careful when your washing the car not to push too hard on the mirror...
Old Jun 5, 2010 | 10:15 PM
guitarplayer16's Avatar
Mine doesn't move smooth either and "jitters" also.
I'm not that fussy.
As long as it still works, I'm not fussing about it.
Old Jun 5, 2010 | 10:54 PM
csmeance's Avatar
this is a common problem on the TL's, the assembly either needs to be lubed up well or replaced. Most dealers replace the whole assembly as it's easier.
Old Jun 6, 2010 | 07:01 AM
K-TL's Avatar
4th Gear
I have an 06 TL & my right mirror does the same thing. When you switch to the left mirror for reverse tilt, it's not a problem. I never thought this was an issue till I read all the other posts. I'm still under extended warranty so I think I'll get it fixed.
Old Jun 6, 2010 | 10:50 AM
BG74's Avatar
I found with mine that simply moving the mirror as far as it can go in every direction solved the problem. I guess the grease that it is applied to the little jackscrew mechanisms needs to be spread out once in a while.
Old Jun 6, 2010 | 01:47 PM
Hm, I'm going to go try that out =)
Old Jun 7, 2010 | 07:04 PM
bagg3r's Avatar
6th Gear
good idea on moving it in all directions. gonna give it a shot.
Old Jun 8, 2010 | 08:37 PM
ilewis33's Avatar
5th Gear
There's a TSB about it. If the car is under warranty, it should be free, and it looks like it should take about 15 minutes if they have the part:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
http://www.in.honda.com/rjanisis/pubs/SB/B09-047.pdf
Mine does it too, I need to take it in.
Old Jun 9, 2010 | 03:18 AM
winkyyy's Avatar
same thing happened to me when i first got my car. didnt notice it till i drove home from the dealer. but they fixed it with no questions asked. they said they replaced the whole motor inside or something like that. i cant quite remember. but now mines glides down smoothly.
Old Jun 9, 2010 | 03:28 AM
LatinSmoke 01CL's Avatar
Same thing was going on with both my mirrors. Dealer replaced under warranty...
BoricuaTL
Apr 8, 2016 01:08 PM
Rocktman1
Oct 31, 2015 02:33 PM
Sep 17, 2015 10:16 AM
PortlandRL
Sep 14, 2015 12:01 PM
dre707
Sep 8, 2015 08:32 PM
