Side Engine Mount Carnage [pics]
Old Jun 9, 2012 | 02:35 AM
Majofo's Avatar
Exclamation Side Engine Mount Carnage [pics]
I knew it was bad, but didn't know it was this bad. Morale of the story, if your dust cover is cracked.. replace it, now.
Also, if the side engine mount is this bad, you can imagine the rest.
Old Jun 9, 2012 | 05:45 AM
paperboy42190's Avatar
not the worst i've seen. on my accord, the mount was completely torn to 2 pieces, so basically it was the same as no side mount.
Old Jun 9, 2012 | 05:46 AM
btw is that an aftermarket new side mount? it has an aftermarket look to it, my oem one looks slightly different i think
Old Jun 9, 2012 | 08:28 AM
Majofo's Avatar
It's OE.
Old Jun 9, 2012 | 08:43 AM
mb1976's Avatar
How are the other mounts looking?? Like Transmission mounts, Front Motor mounts, and Rear Motor Mounts?
Old Jun 9, 2012 | 08:56 AM
Majofo's Avatar
I haven't heard the front engine mount knock but I'm sure it's taken more than it's share of abuse. No vibration from the rear so I'll spare it. Upper trans mount will be replaced with front engine mount. The upper trans mount has some wear and tear but doesn't look as bad as I've seen from other members.
Old Jun 9, 2012 | 09:00 AM
mb1976's Avatar
If the rear one is bad when would you feel the vibration during acceleration or just idling?
Old Jun 9, 2012 | 06:56 PM
Majofo's Avatar
in idle, especially on an incline.
Old Jun 9, 2012 | 08:22 PM
ez12a's Avatar
the overexplainer
yep, ditto the cracked dust cover being a sign. Mine had a tear in it but it wasnt fully disconnected, dust cover had a crack.
Check yer mounts, people!
Old Jun 10, 2012 | 05:50 PM
ghettocrxsi's Avatar
Just replaced all my mounts, they were all in two pieces at 88k miles. Complete junk. 400.00 later I replaced them all my self.
Old Jun 11, 2012 | 06:25 AM
gideon's_test's Avatar
Yup. At 75K miles mine had a bad front and side mount. Replaced with the XLR8 60A kit.
Old May 25, 2014 | 10:42 AM
Majofo's Avatar
bump
Old May 25, 2014 | 06:07 PM
I hate cars's Avatar
My side mount came out in 2 pieces. Did all mounts. It feels like a new car. I did the side mount on the fiancées Murano because the engine moved enough to stretch the power steering hose and cause a leak. I've learned that whenever a chick complains that it feels like an old car or a "junky" car with no other description it's mounts or suspension.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
