shifter/gearbox
Addicted to Speed
shifter/gearbox
Im replace the section that the shifter (auto) slides up/down/left/right today. I found that i needed to when taking it apart to clean and noticed broken peices in and around the base. I do drive the hell out of my TL I have every bolt on + NOS + Apexi Fuel/Air ECU possible. Ok.......Is there a stronger or heavy duty type section that im replacing for a 2004 TL automatic? My illustration of the area is called "select lever B-35" in the "Chassis" section of the acura print out
