Shaking problems!!
Shaking problems!!
car shakes a bit when above 60, steering wheelshakes too. When braking above 40, mostly on the highways theres a lot of vibration coming from the rear of the car. New rotors, new breaks. Can it be bent rim>wheel off balance> bad tires?
Stay Out Of the Left Lane
Received 1,236 Likes
Could be either of those. How sure are you the vibration is coming from the rear? Have you tried rotating the tires to see if the vibration moves? What year is your TL? How many miles? How many miles on the tires? Give us some more info to work with.
05 tl with 133k miles. around 3000 miles on the tires but my back right tire is really worn out. My mechanic is its comning from the back and you could hear it. he told me to change the rotors and brakes but that didn't seem to sovle the problem. and no I haven't tried rotating thewheels
You have 3000 miles on your tires, but the back right is really worn out?
Depending on how bad your tire is, you may be looking at replacing it. As Polo suggested, an alignment is in order and/or rebalancing of the tires.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
