Serpentine Belt Replacement
Old Jul 19, 2010 | 10:43 AM
bshevchuk's Avatar
I have an 04 6MT TL and need to replace the serpentine belt. From my research I have found that its is auto tensioned, but I cannot figure out how to get it off. It seems more accessible from the passenger side wheel well after taking off fender liner. Is there some hole to put a ratchet in to loosen the belt? Thanks.
Old Jul 19, 2010 | 11:32 AM
Turbonut's Avatar
Tight quarters but you can access leaning over the pass fender. Put a wrench on the tensioner bolt, eat your Wheaties, and give a constant pull. When installing, make certain the belt is correctly placed, pull on the tensioner and slide the belt on.
Here's some info and pictures if you scroll down the thread.
Old Jul 19, 2010 | 11:46 AM
DeathMetal's Avatar
Fearless DIY Guy
https://acurazine.com/forums/showthr...ng+belt+change
Old Jul 19, 2010 | 12:31 PM
bshevchuk's Avatar
Ok, I will attempt this on Saturday. There is no diagram of how the belt goes under the hood, but I think I should be able to not screw it up.
Thanks for your help.
Old Jul 19, 2010 | 12:49 PM
Tehvine's Avatar
6spd FTW
I just went out and did mine, took about 10 minutes.
Just cut the wheels all the way to the right, draw a belt map, relieve tension on tensioner and slip belts off. I had to reach through the wheel well to get the belt on the crank pulley. Other than that, it's straight forward, get the belt on all the pulleys except the tensioner. Get the belt in front of the socket or whatever you used to hold the tensioner (front being towards front of the car), apply pressure and slip it on the tensioner. Done.
Old Jul 20, 2010 | 03:52 PM
bshevchuk's Avatar
Seems simple enough.
01CLOwner
Oct 9, 2015 01:07 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
winkyyy
Sep 11, 2015 04:40 PM
Phambam12
Sep 5, 2015 04:10 PM
asahrts
Sep 4, 2015 05:55 PM
