Seat Doesnt Slide....
2004 AM TL.......
whatsup everyone i took about 1/2 an hour to search for an answer no luck lol my passenger side seat only seems to fold back and forth but Doesnt Slide At All Happened Out Of The blue ..... are there Seperate Fuses for Each Movement? any info would b greatly appreciated thanks
Passenger seat fuses are 13 (recline) and 17 (slide). This is all in your owner's manual, page 248. Quite likely, fuse 17 is blown, 20A.
2004 AM TL.......
2004 AM TL.......
i finally got around to checkin fuse 17 and 13 both r fine so i guess ima going to have to replace pass. side seat motor? anyone else have had this issue?
Did you try replacing fuse 17 with a new 20A fuse just to be sure?
If not a fuse, it could be:
1. bad motor
2. bad switch
3. loose connection (be sure to check all of the connectors under the seat, there are 3 of them I think)
4. broken/shorted wire
1. bad motor
2. bad switch
2004 AM TL.......
^^^ yea replaced fuse and still had the problem i guess ima have to take a trip to dealer since im mechanically challenged lol thanks for the help
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
