screws and clips for splash shield
Hi!
I was under my car changing oil this weekend and noticed few clips and screws are missing on what I think is call splash shield at the front of under the engine bay. I found it in the manual on page 20-143, but it doesn't specify the part numbers. And there seem to be two different fasteners. One with the Phillips head and one flat plastic top (see pics attached). Can someone help with either part number for those or a name/link so i can buy and replace them?
Thanks!
Thanks!
www.acuraoemparts.com or www.oemacuraparts.com
you will then have to investigate to find the diagrams to find the part # to order.
I'm still confused about the phillips head screws (top of my original image). the hole in the metal behind the plastic shield is way too big for the screw to work there. that screw is not shown on the diagram, but is mentioned in the manual. it seems like it would be this screw:
but i can't see how it would work in that location. i think i'll just try to use the plastic clips everywhere...
hey, thanks for your help! i found what i thought was the right part (91503-SZ5-003), but it seems like it's 91503-SZ3-003, so i'm happy i haven't bought it yet..
I'm still confused about the phillips head screws (top of my original image). the hole in the metal behind the plastic shield is way too big for the screw to work there. that screw is not shown on the diagram, but is mentioned in the manual. it seems like it would be this screw: https://www.amazon.com/dp/B0040D0OLS...v_ov_lig_dp_it
Behind it, there's typically there's clip nut" as such: 90305-SM4-003
you're da man!! thanks a lot!
Dook303
11-08-2011 11:55 PM
