Salt stains
Old Mar 2, 2015 | 07:38 AM
Waldo's Avatar
2007 Type S
Salt stains
is there any secret elixar to remove salt stains from the carpet around the go pedal, i have Weathertech mats in there, but still have acquired some salt stain, have tried a few different things, but nothing works yet.
Old Mar 2, 2015 | 09:12 AM
polobunny's Avatar
Registered Bunny
Half water half white vinegar in a spray bottle. Dampen the salt spots, scrub lightly, blot with a dry towel, repeat a few times until the spot is gone. Air the car out as much as possible so it doesn't smell like vinegar for too long.
Old Mar 2, 2015 | 09:18 AM
Waldo's Avatar
2007 Type S
yes, i tried that on the floor mats 3 or 4 times in the basement, still can t get rid of them, so will very hard to remove them from the carpet, need something a little more agressive it think, tried mr and mrs Clean, but to no avail.
Old Mar 2, 2015 | 10:18 AM
polobunny's Avatar
Registered Bunny
Warm water and vinegar is the only thing I use for salt most times. Remove the excess salt with your fingers/nails before trying to blot it.
Just brush it a bit but not too much with a scrubbing brush, you don't want to make the salt go deeper, you want to dilute it.
Otherwise you can use carpet shampoo for the harder stains and let it sit a bit, but personally I've found vinegar to work just fine.
Old Mar 2, 2015 | 10:37 AM
EddieOnAZ's Avatar
Turtle wax makes a product especially for this. It's a spray bottle that shoots foam. You let the foam sit on your stain for a minute then you brush with the plastic brush included with the bottle and then you wipe off. I've had good results so far.
Old Mar 2, 2015 | 10:51 AM
guitarplayer16's Avatar
I use white vinegar and water mixture.
Works on my boots too.
Old Mar 2, 2015 | 07:26 PM
Steven Bell's Avatar
I've got this problem next to my accelerator. I'll have to give this a try.
Old Mar 3, 2015 | 09:15 AM
WDPanda's Avatar
A good brush, warm soapy water and some muscle power.
Old Mar 3, 2015 | 09:20 AM
Waldo's Avatar
2007 Type S
that certainly doesn t work.
Old Mar 3, 2015 | 09:22 AM
WDPanda's Avatar
You'd also want to vacuum it as you work. Works for me everytime.
Old Mar 3, 2015 | 03:22 PM
314_04TL's Avatar
Bissell mini green machine carpet cleaner I bought two of them it works that good
Old Mar 3, 2015 | 05:19 PM
se05's Avatar
Did you boil the water?
Old Mar 11, 2015 | 02:58 PM
mazen222's Avatar
Good timing, i have lots of salt there from this winter as i didnt place my ruber carpet properly.
I have a bottle of CLR, i was going to try it, but i'll go with the water/vineger
Old Mar 11, 2015 | 03:47 PM
Waldo's Avatar
2007 Type S
good luck, it sure didn t work for me. i tried warm water, 50 /50 water vinegar on my mats, gently, nothign, aggressivly, nothing. i need to find some product to clean them. i have them on my bench and tried most everything, short of burning it.
Old Mar 11, 2015 | 05:13 PM
polobunny's Avatar
Registered Bunny
Bench? Are you taking about the leather?
Old Mar 11, 2015 | 07:08 PM
Waldo's Avatar
2007 Type S
no, am talking about the mats.
Old Mar 11, 2015 | 07:30 PM
polobunny's Avatar
Registered Bunny
So uh... come again? Bench?
Are you sure it's a salt stain? I've never had trouble removing them with water/vinegar and a brush like I mentioned earlier. It's not instantaneous, but it works. You soak and blot until the stain disappears.
Old Mar 11, 2015 | 07:35 PM
Waldo's Avatar
2007 Type S
i have the mats on my bench in my garage, i have tried blotting, scrubbing gently, scrubbing aggressivly, warm water, warm water and vinegar, mr clean, soaking, and yes it is salt stain. should have took them out sooner than i did to replace with the weathertechs.
Old Mar 11, 2015 | 07:38 PM
polobunny's Avatar
Registered Bunny
Oh, makes more sense.
Going to the groceries and renting a carpet cleaning machine would be my next step.
Old Mar 30, 2015 | 01:16 PM
cruisingnycfl's Avatar
how about a degreaser, spray it let it sit for about like two minutes, and then brush it with some warm water with carpet soap
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Silvermoon_Knight
Oct 22, 2015 06:25 PM
IIDXholic
Oct 8, 2015 07:53 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
