Rough idle
Old May 17, 2010 | 11:13 PM
J72989's Avatar
5th Gear
Rough idle
So lately I've been noticing my TL shakes a bit about a minute or two after I start it, then runs smooth afterward. I was thinking about replacing the spark plugs and (maybe?) the coil pack as well? I've been searching forever and cannot find ANYTHING on after what mileage should the coil pack be changed. Mine is at about 58,000 miles. What else could this possibly be, if not the plugs?
Old May 17, 2010 | 11:16 PM
purple_illusion2's Avatar
maybe check your PCV
Old May 17, 2010 | 11:27 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It could be a bad coilpack. It could be a spark plug. But coilpacks are good for a long time.
Old May 17, 2010 | 11:38 PM
01tl4tl's Avatar
coilpacks are only replace if fail
spark plugs 60kmiles is ready for them
seafoam- 1 can to just under 1/2 tank for cleaning from injectors to cat will usually fix a miss,, if its not a real serious problem --just gunked up
Old May 18, 2010 | 12:18 AM
Acuratl604's Avatar
where can i get this seafoam? i live in canada and no one has heard of it..... i've been wanting to try this for awhile now.
Old May 18, 2010 | 12:28 AM
HokAy's Avatar
autozone or a walmart or something similar to those stores! and my second seafoam is due soon! cant wait for that.
Old May 18, 2010 | 02:33 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
swap the plugs before you do anything else...
if the problem is still present get a compression test done...
Old May 18, 2010 | 11:46 AM
01tl4tl's Avatar
canada has seafoam- the big tire store chain iirc
there are many Canuks here- ck the local Meets section to find one near you to ask
Old May 18, 2010 | 11:48 AM
01tl4tl's Avatar
dirty injectors will cause rough idle- been running 91-93 octane from name brand stations?
plugs are about ready based on miles if extreme use- ie driving on Earth
Old May 23, 2010 | 11:30 AM
J72989's Avatar
5th Gear
Only 93 from Hess, or Shell.. and if I'm desparate I'll settle for 92 from Wawa.. I haven't checked the spark plugs yet, will do asap. The car is also making a "putt putt" sound from the back of the exhaust. I'm hoping changing the plugs & a treatment for the fuel injectors will be the fix. :\
Old May 23, 2010 | 11:31 AM
J72989's Avatar
5th Gear
But I am not the first owner of this car.. I've only had it for about a year and a month. Got it from an Acura dealer by me in NJ so I have no idea what the previous owner did or didn't do to it.
Old May 23, 2010 | 12:13 PM
BradE's Avatar
The car is designed to have a rough idle at start. The car intentionally misfires to heat up the cats quicker to reduce emissions, that is part of what makes it ULEV. It's normal, there is nothing wrong.
Do a search, this has been discussed many times.
baelim
May 10, 2018 09:53 AM
DerrickW
Nov 15, 2015 05:52 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
ceb
ILX
Sep 27, 2015 10:56 AM
