rotor problems
Old Sep 15, 2010 | 07:58 AM
amaniTL's Avatar
rotor problems
IM feeling vibration in the left front wheel and was told the rotor have a slight bend.Is it ok to just change one rotor or just do both??
Old Sep 15, 2010 | 08:09 AM
05TLdcc's Avatar
Coal
change both, but why would you put up two new threads asking the same question
Old Sep 15, 2010 | 08:13 AM
nfnsquared's Avatar
It's OK to change one at a time, but you need to ask yourself why is this rotor bent/warped? I'd probably just go ahead and change both unless they are relatively new rotors. How many miles do these rotors have on them? If the rotor is warped due to being worn thin, it's only a matter of a very short time before the other rotor will need to be replaced. Not to mention that you will be replacing opposite rotors at irregular intervals if you just replace one.
Old Sep 15, 2010 | 12:03 PM
amaniTL's Avatar
ok the car has 6200 miles on it but it was also in a accident and was hit on the same side
Old Sep 15, 2010 | 12:04 PM
amaniTL's Avatar
i thought i put it in the wrong sectio thanks anyways
Old Sep 15, 2010 | 12:39 PM
nfnsquared's Avatar
If the accident was covered by insurance, I'd go back to the insurance company and let them know that the body shop didn't fix everything and they need to replace the rotor. With only 6200 miles, you'll be fine just replacing the one rotor.
Old Sep 15, 2010 | 01:28 PM
Turbonut's Avatar
If the pads are still in great shape, you can change one rotor, but it would be much better to change both as if one will become out of spec, the other will follow. If the pads are quite worn, replace them also.
Old Sep 15, 2010 | 11:24 PM
amaniTL's Avatar
ok thanks alot i will
Old Sep 16, 2010 | 05:26 AM
Turbonut's Avatar
Noe that my response was moved to this thread, with 6200 miles and as the car was involved in an accident on that corner, no problem in changing one with an OE rotor.
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Brandle34
Sep 23, 2015 07:20 PM
