Rocking Driver's Seat
Howdy folks,
My driver's seat has a slight rock to it, most noticeable when accelerating and braking. I know that in order to fix it, you have to remove the seat and tighten up a few bolts.
My question: For those of you who have had this problem, how much did your dealer charge, or did you just take it to a mechanic and have them do it? Is there a simpler fix that I may have missed?
Thanks.
Thanks.
Howdy folks,
Thanks.
Thanks.
It's funny you posted this. I am having the same problem with my 2006 TL. I just took it to the dealer today to be fixed. IF the repair is covered by the warranty it will be free. If not, I was quoted $66.00 to fix. I'll let you know.
I had this problem as well, there is a TSB on it. It was fixed under warranty, if I remember correctly they replace the entire bottom seat frame. I think that part runs $300-400
Fearless DIY Guy
Might be. The seat is secured to the body using 4 19mm or 21mm bolts, I forget which, specifically. Grab a wrench, and start turning clockwise. If that's not it, take the bolts off, tilt the seat back, and look at the fasteners to see if you can DIY any loose bolts.
I had that happen with my 04 tsx and the dealer finally replaced it under warranty. Seemed i was the only one who could feel it but it drove me nuts.
if you still have warranty they should fix it.
rockyboy
08-04-2024 10:35 AM
BoricuaTL
04-08-2016 01:08 PM
