Rocking driver seat 04 TL 6MT
Old Jan 21, 2010 | 02:51 PM
moodymaverick's Avatar
My driver seat rocks if I brake heavily or make sharp turns. well not a lot but i feel the seat move a little when I do that. I am able to move the seat back and forth and tilt with no problems using the buttons.
I took it to the dealer and he said the seat track needs replacement and it would cost $1250!!!
Has anyone had this issue?
I do have extended warranty from Curry acura and my dealer (not curry acura) says it is not covered because of the type of wear. usual bull s**t!
Could this be something i can do myself?
Old Jan 21, 2010 | 10:16 PM
BigRedTL's Avatar
Hey man check your blots under your chair there probably a little loose, I had the same problem with mine were when I brake my chair would rock back and forth. Notice it was loose when I was cleaning my car.
Old Jan 22, 2010 | 09:54 AM
Did you mean bolts?
Old Jan 22, 2010 | 06:51 PM
ggesq's Avatar
OP- there is a TSB on this issue. My dealer fixed my rocking seat per the TSB.
edit- look at this TSB and see if it applies: http://www.in.honda.com/Rjanisis/pubs/SB/b08-004.pdf
Old Jan 25, 2010 | 12:00 PM
Thanks. This looks like the issue. I would have to remove the seat then to fix it. Is there a DIY for that? Where can I find 04TL service manual?
Old Dec 17, 2018 | 08:36 AM
GhostTL09's Avatar
opening up an old thread, oh well it's a concern many may have so here we go.
I didn't read the TSB but my 08 Type-S was having the loose clunk feel and sound on acceleration and braking. I took the seat out, scratched my head, played with a few bolts and nothing was loose. I then noticed the tension cable in the front was loose and I tightened that up and it put some tension back on the rails. I didn't know if I solved the issue but I had no other ideas. I put the seat back in and had to use a bit of force to re-align the bolt holes because the rails I'm assuming had proper tension again. I got everything bolted in and......
1. My seat slides as quiet as I have ever heard a seat move in all directions
2. There was no vibration when the seat moved
3. When accelerating and braking my seat felt firm, zero rocking and clunking anymore
4 I don't feel like I'm gonna fall out my seat and all I had to do was tighten the rail tension cable
before going to dealer just look and see if your tension cable is loose. Hope this helps anyone with this issue
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
cm561
Jan 27, 2016 10:17 PM
kareshi
Sep 3, 2015 03:38 PM
