Reversed Battery Terminals
My battery was dead so I went to put a fresh battery in it and ended up reversing the terminals it was late at night when I was doing this but asoon as I touched the positive on the negative side of the battery it made a spark , that’s when I realized something was wrong , I then flipped the battery the correct way and hooked the car up as normal and the car was completely dead , I ended up blowing the 120/70 fuse. I got that replaced and everything was good , the car fired right back up with the battery indicator on ( wasn’t on before ) was sitting in the car for a few minutes when all of a sudden all the dash lights came on ( VSA , ABS , Seat belt light Etc ) no check engine light , the fuel gauge died right out and same with temperature gauge . I then decided to turn the car off , waited a few seconds then when I went turn the car over it was completely dead , then I proceed to hook the car up to a battery charger to try and boost it , the car will randomly get power and die within a second so I can’t get the car started.(battery terminals are clean and tight) I have a test light and I’ve tested a few things so far , the battery lights up good , 120/70 fuse is getting power , there’s some fuses under the hood that aren’t lighting up (assuming the ignition needs to be on for them to get power) need some help and where I should be looking or if anyone has had a similar problem , the next thing I’m thinking of trying is making sure theres continuity in the starter wire and alternator , test the underdash fuses , if anyone has any suggestions I’m all ears. Just finished spending a lot of money getting all the front suspension good , if I can tackle this rather than bringing it in , that’d be great ! Thanks
2006 Acura TL BASE
2006 Acura TL BASE
Checked all fuses and everything was fine except for a blown radio fuse , car does not crank , it does nothing with a new battery , I gave the car another shot and hooked up the battery again but this time my negative wire started smoking almost instantly after I hooked the terminal up to the battery not sure what’s going on
Does the gauge cluster turn on?
Have you tried cranking in neutral?
Can you communicate with a scanner?
They weren’t turning on anything , the car was completely dead , I get good power to my alternator so I’m thinking my wires are good , but asoon as I remove the power wire from the alternator ( having battery terminals hooked up ) I went to turn the key and I was getting power to everything ( dash lights , radio , etc ) , so I’m thinking I fried my alternator when there was reverse polarity.. hoping I replace this tomorrow and the cars good as new
Earless
1G TSX Problems & Fixes
Aug 10, 2016 07:25 PM
