Resetting the service warnings
Old Aug 17, 2007 | 05:01 PM
madmilk's Avatar
Hey, guys. I've searched the forums already but can't find anything helpful. I have a message on my speedometer telling me that my service is overdue. I had a warning that it was coming up, a warning that it was due and now a warning that it's overdue. I also have an envelope underneath the odometer now. I have to arrow away from the message everytime I start the car.
How do I remove this warning?
Old Aug 17, 2007 | 06:15 PM
Ron A's Avatar
Administrator
Welcome to the forums. Some of this is in the Owner's Manual, but part of it is incorrect and a lot of it isn't explained, so here it is.
This may be more than you want to know, but here's the full procedure to reset the MID display, and also info at the bottom about other service reminders when you manually reset the MID yourself.
The procedure in the owner's manual (and I just checked the 2007 manual and it is just like the 2004 manual) omits the requirement to hold the button down for 10 seconds the second time you press it to clear the display.
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
      This will explain what happens to the other services items when you reset the MID before the service due message appears.
      From the service manual, page 3-6: (NOTE: This information is not in the owners manual.
      NOTE: If you are resetting the display when the oil life is more than 15%, the maintenance message "Service Due Soon" will be displayed. Make sure the maintenance items requiring service have been performed before resetting the display.
      So this means if you change your oil before the 15% Service Due Soon is displayed, and you go to reset the display, if there are other items to be serviced, they will show up on the display, and if you clear the display the MID will take this to mean that you performed the required service.
      To clear the display:
      After you get that service screen hold the reset/select for another 10 seconds.
      It will then ask you if you want to reset.
      Press the reset/select or the YES button (I forget which), and the MID will be reset
      The statement from the service manual is a little vague, and I think they meant to say that if other items require service, the message "Service Due Soon" will be displayed, since if there is nothing else requiring service there would be no need for the message.
      There is an explanation of how the MID works in the Acura Service News for September 2005 http://www.in.honda.com/Rjanisis/pubs/SN/B050900.PDF
      and more about how you will get additional reminders when resetting the MID before it reaches 15% in the Acura Service News for September 2006: http://www.in.honda.com/Rjanisis/pubs/SN/B060900.PDF
      Mike734
      Dec 10, 2021 01:25 PM
      08KBP_VA
      Oct 22, 2019 01:55 PM
      thegipper
      Sep 28, 2015 01:01 PM
      jmaxima03
      Sep 27, 2015 10:22 AM
      95oRANGEcRUSH
      Sep 25, 2015 12:50 PM
