Replacing master window switch driver door
Old May 24, 2014 | 09:39 PM
kidd71's Avatar
Hey all, just bought my '05 TL and the lock out button is missing the cover. I purchased a used switch from a local wrecking yard, but cannot find out how to R/R the unit. There is lots of videos for the TSX, but none for the TL. If anyone could help, would be appreciated. I've seen the video on how to remove the door panel.
Old May 24, 2014 | 10:26 PM
AndrewA's Avatar
Once you get the door panel off, follow the attached diagram. It looks like you remove two screws from inside the panel to expose the switch. Then you pry the switch out.
Attached Thumbnails Replacing master window switch driver door-power-window-switch.jpg
Old Jun 13, 2014 | 01:43 PM
tobmiller's Avatar
Is there a video for removing the door panel? I haven't managed to find one yet.
Old Jun 13, 2014 | 03:13 PM
Vlad_Type_S's Avatar
Registered Bike Offender
https://acurazine.com/forums/3g-tl-2004-2008-93/how-remove-door-panels-3g-garage-f-016-a-559144/
Originally Posted by rets
Old Jun 14, 2014 | 01:51 PM
kidd71's Avatar
just did this R/R 2 weeks ago. The diagram is helpful, but there is a lot more screws holding the arm rest on. I think I counted 5 screws on top and at the botom on my '05 TL. Make sure not to try and force any part of the door panels. If a part does'nt move easily, check for another screw. Also the master switch kind of inter locks with top of the arm rest. all said and done, was a simple job
mada51589
Jan 9, 2025 04:40 PM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
Skirmich
Sep 15, 2015 06:41 PM
