Removing steering wheel stripped screw torx help?
i don't know if anyone have experience this problem, i need to change my steering wheel because the leather was damage by using lexol cleaner (falling apart like an old leather sofa). i need to replace it (got one from ebay), but the screws on the side are TORX 30, which i use, i was able to remove one (they are really tight) but the other one the head stripped now there's no grip. i have been fighting 2 day to get the darn screw out, even went to a few handyman to help out with no luck. how do you get this screw so tight out?
An alternative to drilling:
https://acurazine.com/forums/showpos...8&postcount=11
Sears apparently has a craftsman equivalent to the turbo socket set up. Also, other posts in that thread recommend using a 3/8" drive instead of a 1/4" drive with the Torx bit.
You use a drill bit and drill into the head of the screw till it comes off. Then the airbag will come right off and you can use pliers to take the rest of the screws out. Do it the other way though thats much easier...
Using those should be much easier then drilling the screws out. Ill have to pick up a set for future use.
i went to sears and but the craftsman power bolt-out. let see if this works i'll let ya know. also if i do get the bolt out i cannot use it back, where can i get the same size bolt (i hate torx screw so my get it with a different head). or anyone knows the size diameter so i can just ask in any harware store.
here is the one i bought
http://www.sears.com/shc/s/p_10153_1...man+power+bolt
I stripped the torx bolts bad too. bought the same tool that worked for you, but it didnt work for me. I dont know what else to do now..... Any suggestions besides drilling it out?
Having a similar issue. Broke the head off the left side screw and have stipped the other. Power-out set also does not seem to be working (tried it with both hand and power tools).
Is drilling those screws out my only other option?
merc009
10-03-2015 12:59 AM
