Red Airbag icon has appeared
Yesterday, the temperature dropped to -45 including windchill and noticed the Red airbag icon appeared on the dashboard, tried to shut / no shut the car, icon still stays on.
could be a sensor issues? or just the weather temp?
I had my light come on a few months ago and it turned out to be a sensor in the seatbelt buckle. They had to replace the buckle. It was free since that kinda stuff has a lifetime warranty.
Cb...wind chill doesn't effect the car, only living things. That being said, that is damn cold! Actual temperature would effect all things though with coefficient of expansion based on heating/cooling. Cooling causes shrinkage so a connection may have loosened because of that...
airbag light was gone...since yesterday temp went up from -45 to -20. I didn't do anything, just disappeared.
maybe the sensor is weak and starting to fail...and just a coincidence with the weather...who knows?
Mine was coming on randomly. I could go days without it coming on and when it was on I could turn off the car and turn it back on and it wouldn't be on. But just as a precaution I took it in because I didn't want to get into an accident and have the airbags or seatbelts fail.
good stuff..i will call Acura to book an appoinment ASAP...
did the Acura dealership replaced all or just front seat belts?
They determined it was just one seatbelt buckle that was causing the issue and that's all they replaced. I haven't had the light come on since.
I took the car in for inspections yesterday but they couldn't find anything wrong..just needs a reset..
Here's what Acura had to say..
" 103537 Data retrieve 85-61 no signal from OPDS unit, tried initializing OPDS unit which failed, will need to try a OPDS unit but may have floor harness failure. "
what do you guys think?
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
