Recommended battery brand?
Went outside this morning to leave and when I turned the key all I got was *click click click*. Dead battery. Haven't replaced the battery in this car, what's your favorite/recommended brand of battery? I live in Utah and it's currently about 12 degrees outside so cold starts will be happening.
https://acurazine.com/forums/1g-rdx-problems-fixes-160/dying-battery-help-873995/
And if the TL takes a different battery than the RDX, then be aware that Consumer Reports recommends a different brand of battery for each type/ size, based on their tests. Yes, the same brand can be rated highly for one type and rated very low for another type, i.e., size 78 vs 35.
OP, do a search. I posted a copy of CR battery recommendations..
I bought the Die Hard Gold on sale and it's been rock solid for 4 years now.
It's not needed or required but the Diehard Platinum is an amazing battery and has the best warranty I've seen. $206 roughly but it is made by Enersys (one of the largest battery manufacturers and labeled as a Platinum. This exact battery also gets one of the high end Odyssey labels. The identical battery with the Odyssey label goes for about $100 more. They're not similar, they're identical.
BoricuaTL
04-08-2016 01:08 PM
