Rear View Mirror trembles!!!
solace in privation
Hey guys. Quick question here. My rear view mirror is loose and vibrates when im driving which really renders the mirror useless when driving/switching lanes. Ive taken the plastic cover parts apart and looked for any loose screws. nothing looked irregular. I reattached it but its still shakes despite everything feeling snug in place. any suggestions on how to fix this?
tx in advance!
tx in advance!
If you had done a search for "rear view mirrror" you would have found this:
https://acurazine.com/forums/3g-tl-problems-fixes-114/service-bulletin-rearview-mirror-loose-756603/
There also is a sticky post at the top of the "Problems" forum that will link you to a list of the TSBs. There also could be helpful info on this subject in the 3G Garage (sticky post in the main forum). Welcome and remember: search and the 3G Garage are your friends!
solace in privation
I dont know man some days i found a ton of info and other days the search comes up nothing.Next time I wont be so hasty in posting a problem bf thorough search thanks though!
Head a da Family
I had a similar problem. Dealer replaced the actuator inside the mirror. There's a TSB on this somewhere.
https://acurazine.com/forums/3g-tl-problems-fixes-114/replace-side-mirror-actuator-motor-755014/
https://acurazine.com/forums/showthr...TSB%2BACTUATOR
solace in privation
Yes I went to the dealership today and picked up that spring thing for a buck and some change. the hard part is figuring out how to replace it. I wonder if theres a video on this?
The pictures in the TSB are no help?
solace in privation
just pushed the tabs of the old spring together now its tight . the new was was just as loose. waste of money going to the dealer. story of my life
I was about to do a search for this issue and found this on the first page. I guess too many years of bass has killed the mirror. It's useless even at low volumes.
TSB 06-012: Inside Rearview Mirror Is Loose
had this done on my TL years ago, problem solved!
BoricuaTL
04-08-2016 01:08 PM
dre707
09-08-2015 08:32 PM
