Rear Trunk Switch
Old 08-10-2012, 11:42 AM
ogroncal's Avatar
Unhappy Rear Trunk Switch
Hi, Does anyone know how to fix the Rear Trunk Switch to open the rear trunk from the inside.
My remote work to open the trunk but the pushbutton switch on the left lower corner under the dashboard does not work. thanks!!!
Old 08-10-2012, 11:55 AM
Registered but harmless
Will Y.'s Avatar
Received 1,149 Likes on 775 Posts
Change the position of the switch (located in the glove compartment) used to activate and deactivate the trunk button when giving the car to valets.
Old 08-10-2012, 12:33 PM
ogroncal's Avatar
Thanks for the quick response. I'll try it on my lunch time and let you know.
Old 08-10-2012, 12:35 PM
ogroncal's Avatar
One question out of this topic:
Do you know which wires on the acura tl 2006 to wire LED strip to? I wanted to have them on when ignition key is on.
Old 08-10-2012, 12:57 PM
Acura-OC's Avatar
Ignition key wire.
Old 08-10-2012, 01:31 PM
ogroncal's Avatar
Is this wire located under the hood or inside the car?
I'm hoping I can get an exact location and color of wire to tapped my led red wire into. thanks
Old 08-10-2012, 01:34 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I replied to your post here:
https://acurazine.com/forums/3g-tl-2004-2008-93/installing-led-strip-lights-under-headlights-768210/
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
oyayjoe
09-12-2015 04:40 PM
EE4Life
09-11-2015 10:13 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Quick Reply: Rear Trunk Switch
