Rear suspension squeak
Old Jun 19, 2013 | 01:26 AM
paperboy42190's Avatar
Anyone know what can cause a squeaking noise when going over sharp bumps quickly in the rear suspension? Doesnt happen during mild bumps, has to be something sharp that jolts the rear suspension quickly. It squeaks pretty high pitched, not too loud but slightly noticeable. I have tein S techs and progress RSB(yes the sway bar bushings have a lot of lube)
Old Jun 19, 2013 | 06:28 AM
Slpr04UA6's Avatar
-------Tim-------
I have been having the same problem. I have koni/H&R sports and progress rear bar. I have gone over everything, and bushings are lubed on the swaybar as well. It has to be a pretty quick/sharp bump, and It doesn't do it all the time. I think I have narrowed it down to warmer weather (didn't hear it over the winter months).
Thought maybe it was the Ingalls rear camber bushings at one point, but the Ingalls have been removed.
Old Jun 19, 2013 | 07:36 AM
Project_CLean's Avatar
MMkay.
My first guess would be either sway bar links or strut mounts. Usually if it's the strut mounts,the sound will be heard just as clearly inside the cabin as outside.
Old Jul 20, 2019 | 11:42 PM
Wdp_3g's Avatar
Did you ever figure out what it was? I’m having this problem right now.
Old Jul 25, 2019 | 08:33 AM
DMZ's Avatar
DMZ
Head a da Family
I had that problem in the front. Turned out to be worn strut mounts. Considering what you have to go through to replace them, you're probably better of replacing the whole shock & spring combo at this age. I did. Be sure to do both sides!
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Heyzuez20
Oct 14, 2015 07:18 AM
2012wagon
Sep 29, 2015 04:21 PM
