Rear stock suspension install
I'm trying to install my stock rear suspension right now and I'm having a problem. The bottom of the suspension does not line up to the bracket where the flange bolt goes through. The suspension pieces are sitting really low and I have been trying to push the rotor/hub down but it doesn't come close for both sides. I just swapped out my megan coilovers that weren't that low, maybe 1.5 inch drop. Any tricks as to how I can line these up and move on with my life? Thanks
Thanks guys. I ended up just pushing down on the hub with my foot and weight while lining the shock up and it worked. Took about an hour to do both sides after I figured out what to do. If I would have jacked the hub up it would have gone the wrong way because the shocks were lower than the bracket.
IIDXholic
Oct 8, 2015 07:53 AM
