Rear end squeaking
Old Nov 20, 2017 | 02:17 PM
Mike_Lowrey's Avatar
Rear end squeaking
All,
So recently my rear driver side has light squeaking whenever I hit a bump, hump, dip in the road. I thought it might have been the suspension so I replaced the oem suspension with the Tein SAZ and the squealing continues. Could it be the sway bar links? Or wheel hub? I don't know that much about the components but any help is greatly appreciated! Thanks guys. I attached a picture of the setup, maybe something stick out to someone. Thanks
Old Nov 21, 2017 | 09:02 PM
svtmedic's Avatar
Usually when endlink goes bad or fails. If memory serves it usually makes a clunking noise. My belief in this case would be bushings have dried out. Throwing money at problems without knowing what the problem is actually just empties wallets. I call this a mechanical income suppressor. As anything electronic such as your TV or electronic parts in your car could be considered an electronic income suppressor. Is it a squeal or a squeak and or both. If it's squeak then I would think bushings, if it's both, turn up the music and wait for something to fail completely. No in all seriousness could be brakes. I'm sure somebody that has real knowledge will chime in.
Old Nov 27, 2017 | 08:13 AM
DMZ's Avatar
DMZ
Head a da Family
Squeaking is likely to be bushings. As for which ones, I couldn't tell ya. Stabilizer links make clunking sounds when they go bad.
Old Dec 11, 2017 | 11:48 PM
Hyperblu's Avatar
I can see the endlink boot is torn and bad from the pic.
