Rear Driver side door lock noise?
The rear driver side door is making a weird squeaking/whining noise when I lock the doors.
It started happening after I tried unlocking my door with my remote but my remote wasn't responding.
Then after I unlocked the doors with my key the remote lock/unlock starts working again but the rear driver door is making a weird noise when I lock it but it doesn't make the sound when I unlock my doors.
could it be the actuator going bad?
2004 tl
2004 tl
I'll have to look up the part # as I can't recall it off the top of my head, but just remember that the rear actuator is a different part than the one for the front. The rear one costs about $80-110, while the front one is $20-30 (depending on whether you buy at the dealer or online). Mild PITA to replace, but the necessary instructions can be found with a search on this forum.
72655-SEA-G01
That's the part number for the driver's side rear actuator assembly.
The part number you listed is for the passenger rear door actuator assembly, I believe. Note that there are different part numbers for driver's side vs passenger's side (on top of being different front to rear).
It was -50 here couple days ago and the battery died, I charged the battery and the door stopped making the noise…
I guess it was making the noise because the battery was low, well see how it goes in a couple days.
It's just weird because this never happened before and it only happens to one of the doors.
tman570
Jun 11, 2019 07:56 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
