Really Bad Smell from Heater
First of all thank you guys for replying. It smells like really strong vinegar......or maybe mold......
One of my friends told me to spray some Lysol products near passenger side under the hood.....but I refused to do it because to be honest with you guys I thought it would be dangerous and plus I really don't have car knowledge so.....
Please help me to get rid of these un-friendly smells off my car.....
Thanks guys
Thanks guys
I had to do this when I found a family of mice living in my ducts...It worked fine for me....
https://acurazine.com/forums/showthr...light=cat+food
B A N N E D
also did it smell like dust or dirt or something burning, happens alot when you use your heat for the first time when winter rolls around, but should be gone in a day or two at MAX
you are more likely mold, and if indeed, only way to REALLY get rid of that smell is to pull out the evaporator, and dunk it some shit (not quite sure exactly what it is though) and then put it back in
like a sweet smeel for coolant
Thanks guys for helping me out!
I just have one more question to ask.....
Does antifreeze also affect bad smell when turning heater?
Because my car is at the dealership for service and they recommended to change antifreeze fluid.
They said the color of the fluid looked brownish...so...
Could it be the cause of the bad smell?
If you AF is brown, then I would have it changed out. Use only Honda Type II AF. You should consider adding the extreme cold weather Type II fluid.
But first, you may want to ask yourself why your fluid is brown.
What year and mileage is your TL?
Are you the original owner?
Has the fluid ever been changed? If so, are you certain that Honda Type II was added?
I'd also check your oil for any sign of water/AF contamination, i.e. foaming and/or milkiness in the oil. Could be a sign of a blown head gasket.
I would double check the filter. I was soo surprised at how dirty mine was. Do you smoke? I know sometimes in a "smokers" car the smoke gets trapped inside the vents, then when you put on the heater/AC the mixture of dust/smoke etc could be the smell. other than that I dont know. It cant be a dead animal bc your saying it smells liek mold. last option may be to get those air freshners that lock onto the vent opening.lol.. GL either way.
B A N N E D
Unlikely, unless you have a leak in the heater core.
Biggie_B
02-26-2017 11:14 AM
