Rattle near shifter
Old Jul 11, 2005 | 04:41 PM
BigTone's Avatar
'05 TL NBP/Ebony Auto
Angry Rattle near shifter
anyone else experiencing an annoying sound of plastic rubbing together coming from the center console where the gear shifter is on the automatic transmission TL? its slightly north of the cup holders and the switches to turn on heated seats.. i find if i apply pressure in a few spots, i can silence the sound, but its annoying for sure. makes an all-around great car sound so cheap. 2100 miles only...
rear deck also rattles from music with a lotta bass
any remedies or similar stories would be appreciated
Old Jul 11, 2005 | 09:57 PM
mdarblay's Avatar
shifter rattle
We had the shifter rattle also, the dealer put some foam cushion under the bezel and the rattle is gone, but ours rattled when we accelerated. My Brother in law has the subwoofer rattle also as low as 6 on the volume. The dealer tried tightening the speaker but it is still there, now they might try replacing the child safety seat latches that are in the back.
Old Jul 12, 2005 | 09:17 PM
BigTone's Avatar
next time its at the dealer i'll see if they can do something similar to mine.
Old Jul 12, 2005 | 09:18 PM
Bonedoc's Avatar
VTEC is happiness
Bigtone,
I noticed a rubbing/squeeking sound from the silver trim around my 5AT shifter, and it was new onset. I was taking the car in for a myriad of other noises, and I pointed it out to the mechanic on our test drive. He took one look, and pushed (quite forcefully) on the plastic trim immediately below the silver sections. The outer silver ring "popped" into proper position (they are staggered in height, the outer portion below the inner one), and the noise/movement disappeared...the mechanic shrugged, and I said "thanks". It seems it loosened up over time, and now I know how to correct one noise. I am in a constant battle with the door seals, and I have run out of steam dealing with Acura. I may try to get the dealer to change out my seals at some point, as silicone only silences them for a day or two. But I digress. Hope this helps.
Old Jul 14, 2005 | 04:14 PM
Mucker's Avatar
Yep
Rattled right from the start. Got the dealer to fix it after two weeks. It's complelely gone now. I've got a few other creaks and rattles, some constant, some not. I'll get everything fixed at the first oil change.
Craig
Old Jul 17, 2005 | 08:03 AM
Anubus12's Avatar
I had the same EXACT squeeking noise that you have. It drove me nuts. While I thought it was the shifter plate, for me it wasn't. I found the rattle to be between the aluminum trim pieces to the sides of the NAV system rubbing against the rubber trim. It took me a while to find it. I used silicone spray and sprayed in btw the two pieces. That solved the problem for me. Hope this helps.
Old Jul 18, 2005 | 03:21 PM
scrb09's Avatar
I had a rattle on the center console too...it was when the 2 plates that close the 2 slots behind the gear shifter (the one with the cigarrate lighter and the one above it) rubbed together...my solution was to drive with the top drawer open and the rattles were gone...see if that is your issue.
Old Apr 25, 2008 | 09:46 AM
JohnJr's Avatar
Yes, I dug up an old thread, but why repost when you can revive an old one that is exactly what I was looking for!?!?!
Anyways, I have the shifter bezel squeak/creaking and I'm only at 1200k on the TL. Took it in last week and they replaced the bezel. But they didn't actually get rid of the creaking. I can force it to creak by pushing on the bezel just slightly. It's driving me crazy! When I stop and when I pull off from a light or stop it creaks both ways. Taking it back in on Monday to have it looked at again. I'd fix it myself but I figured I'd give Acura a chance. So far they've refused to fix the rear deck rattling from the speakes. But that's another thread...
Old Apr 25, 2008 | 11:02 AM
vinnier6's Avatar
the bezel around the shifter is easily removed just by lifting it off...then i pulled all the poorly done felt off and replaced it with the soft side of velcro, i trimmed it to fit and pop it back on and no problems since...some things are just better handled by yourself then at the dealer....they just dont care like you do....if you know what i mean...
Old Apr 28, 2008 | 08:32 PM
JohnJr's Avatar
Mysteriously it has stopped... I have a felling it'll be back at some point. When it does, I'll try the felt trick.
Jul 16, 2017 07:33 AM
spoiler900
Oct 10, 2015 06:48 PM
MikeJM310
Sep 24, 2015 07:24 PM
