Radiator/Coolant Reservoir Problem!
2 Attachment(s)
So basically my 2005 TL has had an issue for about a year. My coolant level (from the reservoir tank) would rise and get low frequently. I have had to fill back up to the MAX several times. A few days ago it got really low, and I filled it up again...
Yesterday I was driving and noticed smoke coming from my hood (the needle didn't show my car over heating). When I opened the hood, I noticed there had been a pressure build up or something to cause the coolant to over flow or explode I guess... looking like this... Attachment 47388 Not only did this happen, but the reservoir tank was now topped off (over-flowing almost). Today I was taking off from work and not even a few blocks away, my temp gauge began to rise. When I checked I noticed the cap and hose from the reservoir tank to the radiator was broken... http://i13.photobucket.com/albums/a2...psa2168472.jpg Attachment 47389 Has anybody had a similar issue? I think a temporary fix would obviously be to replace the caps and hose. But that still leaves me wondering what causes the coolant level to rise and drop, and what caused the burst or pressure build up?! |
Check your thermostat, and check your car to see it over heat.
how does the bottom of your radiator cap look? mine broke and didnt hold the pressure and caused a leak from my reservoir cap similar to yours
Originally Posted by paperboy42190
(Post 15022257)
| All times are GMT -5. The time now is 12:39 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
